Home > Technical (L322) > FBH Parking heater as auxiliary or engine pre-heater?
Steaky
Is it possible to program the L322 (TDV8, 07) to utilise the FBH as an auxiliary/engine pre heater instead of a parking heater when activated by remote prior to starting the engine?
On my previous L320 TDV8, the FBH was used as an aux heater to pre-heat the entire engine prior to starting.
I've had a look withi the IID tool settings and can't find anything that would allow that to be selected?
Many thanks Smile
Post #633349 31st May 2022 12:47pm
mjdronfield
I’ve not heard of that before. I know it comes on once you have started the engine to help it warm up in cold weather.
We’re there extra options for running it on the L320 then?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #633351 31st May 2022 1:28pm
RJPotts
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Doesn't the FBH heat the cabin by heating the coolant & thus the heater matrix?
IIRC it has a pump to circulate the coolant whilst the engine is off. 2010 Range Rover Autobiography TDV8 Santorini Black
2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone]
2003 Range Rover HSE Oslo Blue [Gone]
1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone]
1990 Camel Trophy 127 (Workshop Vehicle) [Gone]
1989 Camel Trophy 110 (Workshop Vehicle) [Gone]
1998 Camel Trophy Freelander (South African Team Vehicle)
1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone]
Post #633380 31st May 2022 5:41pm
mjdronfield
Yeah, but I’m imagining the question is for the engine only. I can’t imagine the L320 having a different system to the L322 though. It can heat the engine coolant with the engine off, but only when it’s heating the interior also.
I put the instructions for the FBH into the Wiki a bit back… pretty sure there is nothing in the instructions either.
https://www.fullfatrr.com/gallery/albums/u...rt-t91.pdf
https://www.fullfatrr.com/gallery/albums/u...er_fbh.PDF
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #633382 31st May 2022 6:05pm
Phoenix
The early L319 / L320 have different plumbing, the FBH was only intended as a boost heater when the engine was running and the exterior temperature below 4 deg. C., consequently, if a remote control or timer was added, due to there being no coolant valves to control the circulation dependent on the running / parked state of the vehicle, the whole coolant circuit was heated, thereby pre-heating the engine. L322 was specifically designed to have park heating (and has the valves and control logic to allow it) as well as boost heating for the engine. Later L319 / L320 have the option in some markets for park heating with or without remote control, these also have the correct plumbing so that all the heat is directed into the cabin and not 'wasted' on the engine, I suppose you could bypass the valveset so that the engine is pre-warmed (heated is a bit of a stretch) if you really wanted to.
Post #633385 31st May 2022 6:43pm
RJPotts
Alas last winter here was the mildest I've known so I only used the FBH / remote on mine once (apart from making sure it worked).
Interesting bit in that manual about the changeover valve; "A changeover valve allows the heater coolant circuit to be isolated from the engine coolant during parked heating, to reduce the warmup time of the passenger compartment". Which seems to indicate my belief that it just heated / circulated coolant (via the engine) was wrong. 2010 Range Rover Autobiography TDV8 Santorini Black
Post #633387 31st May 2022 7:07pm
Phoenix
The FBH (Thermo Top C in L322, Thermo Top V in early L319 / L320) has a circulation pump, if this is not detected as running in park heating or boost heating, the FBH will shut down,.
Post #633389 31st May 2022 7:18pm
