every time we tried to clear the fault codes ( DTC's ) they would return immediately, this included SDD ( Sympton Driven Diags) scanner, the latest Snap On, and many others since April
we tried to troubleshoot this since April - since it can be a MOT failure
so a new battery was installed back in April when we had the MOT done, on a CTEK trickle charge
the voltage was proven to be good to the SRS DCU - so no problem there
all the sensors located and cleaned and checked all wiring - there are 8 crash sensors I think
loads of other rather pointless and stupid things to go through which really has no bearing on the problem - hey ho
finally decided to swap out the SRS DCU today with one that was exactly the same Bosch part code from a 2004 Range Rover
 | Click image to enlarge |
and now working fine - yay
but will know for sure after several trips over the next few weeks, but the fact that the SRS DCU can be reset was a big step forward - we could never do that before !
