Home > Technical (L322) > SRS Module/ RCM Module
pcourtney
every time we tried to clear the fault codes ( DTC's ) they would return immediately, this included SDD ( Sympton Driven Diags) scanner, the latest Snap On, and many others since April
we tried to troubleshoot this since April - since it can be a MOT failure
so a new battery was installed back in April when we had the MOT done, on a CTEK trickle charge Rolling Eyes
the voltage was proven to be good to the SRS DCU - so no problem there
all the sensors located and cleaned and checked all wiring - there are 8 crash sensors I think
loads of other rather pointless and stupid things to go through which really has no bearing on the problem - hey ho
finally decided to swap out the SRS DCU today with one that was exactly the same Bosch part code from a 2004 Range Rover
and now working fine - yay Smile
but will know for sure after several trips over the next few weeks, but the fact that the SRS DCU can be reset was a big step forward - we could never do that before !
Post #643835 24th Sep 2022 5:48pm
Phoenix
We've had a few like that - won't clear DTC's, different marque but similar age - put down to 'internal non-recoverable defect, replacement required'. I'm sure that some of the vehicle modules have a counter on the number of times you can clear the flash memory before it locks, I've seen it on all kinds of modules, usually the one with a history of faults stored over the years...
Post #643838 24th Sep 2022 6:03pm
pcourtney
thank you for your guidance, I will be honest with you, I have been putting the job off for 3 or 4 months, but wanted it done well before winter, and we will see if it holds up until the April 2023 MOT Big Cry
Post #643843 24th Sep 2022 7:05pm
Phoenix
I'm sure it'll be fine Thumbs Up
Post #643844 24th Sep 2022 7:31pm
