Home > Off Topic > ULEZ expansion
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
If you do some research it's possible. My subaru impreza wasn't originally compliant but after I done some.research I found it was compliant so arranged for a coc form to be sent out
Post #633635 3rd Jun 2022 4:31pm
GGDR
Quote:
I wonder if there’s a way of getting Ulez compliance to older tdv8 4.4 engines…
I've done some digging and whilst it would be possible to add an Adbue system, the problem is getting type certification which only manufacturers or large conversion outfits seem to be able to get.
This is based on NASA levels of data and a testing procedure with equipment on the vehicle over a series or road conditions usually done at a testing ground. The results of which set a car's co2 etc figures - and it's EURO rating.
Additionally TFL have to recognise and accept test methods and the type certification.
TFL upgraded a load of their busses from Euro5 to Euro6 which cost a lot and of coarse they accepted their own programme.
Private car as a one-off? It's just not practical sadly.
If TFL was serious about reducing pollution they would make converting Euro4 & 5 cars feasible but they just want the money.
. Cheers, Greg
Post #633701 4th Jun 2022 10:37pm
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
Lad wrote:
Early stages for whole Uk road driving tolls. This GOV will even tax you for having a car even though it’s never driven on the road.
ie you own it we tax it
I think you will find that applies to ANY government.
Post #634231 10th Jun 2022 6:07am
JMC
The really bizarre aspect of ULEZ is the fact that the most polluting vehicle I own, (which is also the noisiest and can see only 4mpg on a serious run), is permitted to enter without a charge! Shocked The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #634241 10th Jun 2022 8:54am
