Home > Maintenance & Mods (L322) > Coolant confusion!!
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
Coolant confusion!!
I'm sorry if this has already been covered, but the coolant level in my L322 is below both of the "Cold Fill" lines, so I'm guessing it needs topping up.
My L322 is a 2007MY, with the later 4.4 Jaguar V8 Petrol engine and 6 speed box. The manual tells me I need Havoline XLC to
WSS-M97B44 (Texaco XLC) whatever that means.
I feel almost 100% certain that the last time Halford's told me to buy this OAT Ready Mixed - See link below:
https://www.halfords.com/motoring/engine-o...30840.html
Now it's suggesting these two options:
https://www.halfords.com/motoring/engine-o...00407.html
Or this
https://www.halfords.com/motoring/engine-o...00399.html
I prefer ready mixed if possible.
Does anyone know if this has changed from the OAT version as a recommended product, or am I just losing my marbles and the later two recommendations are correct?
Many thanks in advance.
Post #630976 8th May 2022 3:07pm
aja500
The colour of what's already there is Pink, I did read that you shouldn't mix different types.
Post #630977 8th May 2022 3:13pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
amazon do havoline xlc concentrate extended £12 for a litre okay if you are only going to top up i think it is orange should be good for what you want new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #630978 8th May 2022 3:17pm
aja500
Thanks Oggy - Is it OK to mix with the pink though - I did read that mixing colours could lead to a gel like substance developing in the tank
Post #630981 8th May 2022 3:25pm
oggy
well i have seen that stated on the site about mixing . i think what i would do is bite the bullet and drop all old out because do you know when it was last changed . i expect it could do with a change any way and buy 8 ltrs of the write stuff as we have spoke about the havoline xlc i think it is 14 ltrs so half that 7 ltrs and one to keep for top up so get 8 check hand book for total coolant when drained could be less new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #630986 8th May 2022 3:52pm
aja500
For what it's going to cost Oggy, I think that's probably good advice....... I'll look to empty and replenish with the right stuff after my trip later this week. Thumbs Up Thumbs Up
Post #630998 8th May 2022 5:17pm
garyRR
It's 50/50 pink/red stuff with de-ionised water.
The system needs nearly 10L anyway so, buy 1x 5L de-ionised and 1x 5L pink, pour out half the de-ionised into a jug / bucket/ empty container (use the kitchen scales if necessary). The other half won't thank you if you use the glycol coolant to do the measuring!!!!
Fill the half empty de-ionised with the pink stuff and fill the now half empty coolant container with the 2.5L of de-ionised you decanted earlier.
Hey presto, you have 10L of exactly 50/50 mix. Doesn't matter which you buy - they're all made to the same international specification. Should cost about £20-25 for 10 litres in total from somewhere like Eurocarparts. 2015 Range Rover Autobiography 4.4 SDV8
Post #632417 21st May 2022 9:16am
Yes change it would be optimum... Should be changed every two years or so... Environmental laws mean its made to degrade VERY quickly now (in case it spills into a watercourse in an accident)...
Only the early BMW engined cars took blue antifreeze... Everything since is pink Thumbs Up
Post #632464 21st May 2022 5:20pm
