Home > Maintenance & Mods (L322) > Underbody rust on 2012
rednaxela
Hi,
After being into defenders for the past number of years I've decided the natural progression was to a RR Smile
The other week I bought a 2012 TDV8, 136k miles. When I was viewing it I gingerly looked underneath, didn't want to go too overboard incase the dealer wasn't happy about a customer rolling around under a vehicle.
I've had more of a look now, and I'm just wondering what peoples' views are on the state of rust. At the end of the day it could always be blasted/wire brushed, repainted and waxed, but even so, perhaps they are other vehicles out there of similar age/mileage which aren't like this.
I've tried to upload photos here but get 'error uploading album data'.
Here's a link to show the photos on LRUK where I also asked, hope that's ok.
https://www.lrukforums.com/threads/2012-l322-rust.277378/
Thanks
Post #630364 2nd May 2022 9:29am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Nothing out of the normal there. It depends where the vehicles been / sat etc.
All looks straight forward to clean up. Just your time & what proceess you use Thumbs Up
Post #630366 2nd May 2022 9:36am
TJH1985
When I was looking for a L322, 8 years ago there were plenty of examples much worse than that around then, it’s a real shame.
Yours doesn’t look too bad, but you never know about the body until you start to address it. The first thing I did with our old one was remove all the plastics, arch lines etc clean it up spray anything that needed it with Buzzweld Rust/CIO and then put a couple of hundred pounds worth of Dintrol into it.
The L405 has some components that do a equally good job of rusting so clearly JLR haven’t learnt. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #630372 2nd May 2022 9:58am
Charmer
Have you taken the plastic sill covers off to see what the rear arches are like?
Post #630413 2nd May 2022 4:28pm
AJGalaxy2012
I had a 2012, when it was 7 years old it had the front subframe off for the turbo drain mod, the corrosion was horrific, I would expect much better protection from the tin worm than JLR deem necessary. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #630426 2nd May 2022 5:58pm
Range Rover L322
I had Raptor coating done after taking the rust off.
It is used extensively in the US but less so in the UK.
I researched it in depth and am comfortable it is very durable and long lasting.
 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #630470 2nd May 2022 11:10pm
rednaxela
I haven't checked the sills properly yet. As the consensus suggests, it should all be treatable etc. Thanks all !
Post #630554 3rd May 2022 4:49pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Mine is a 2011 and there's nowhere near as much corrosion on mine as that one. It looks like surface stuff but even so, has it lived by the sea? Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #630558 3rd May 2022 5:15pm
rednaxela
Impressive work above.
Not sure about how much time it has spent by the coast, I'd blame a combination of poor steel protection and time spent on salted roads. Only removed one sill cover plug and peered in, but although it sounds an oxymoron, my gut feeling is that the sills may be alright.
Was able to upload these photos using my phone. I used a ball peen hammer to tap at the flaky rust/old coating and the result shows the difference in thickness. If I got the subframe shot blasted in situ I’d expect the metal to be even more pitted and thinned slightly after that. :/
Post #632441 21st May 2022 1:41pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
i use a lot of raptor coat it is a very hard wearing coat . but for a good coat of wax i have started using lanoguard you can cover every thing even exhaust so no masking about £50 for 2 ltrs and it covers well and seems to last easy to re fresh just cover brakes etc new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #632450 21st May 2022 2:54pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
hey oggy. How much Lanogard does it take to do the underside?
Post #632458 21st May 2022 4:52pm
oggy
it goes a long way you would have a drop left if you got 2 ltrs . they also do a tub of grease that you use over more heavy parts that are rusty a lot of vids on you tube have a look oggy new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #632462 21st May 2022 5:18pm
