Home > Maintenance & Mods (L322) > Underbody rust on 2012 |
rednaxela Member Since: 02 May 2022 Location: United Kingdom Posts: 11 |
Hi,
2nd May 2022 9:29am |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
When I was looking for a L322, 8 years ago there were plenty of examples much worse than that around then, it’s a real shame.
2nd May 2022 9:58am |
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 |
Have you taken the plastic sill covers off to see what the rear arches are like? |
2nd May 2022 4:28pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
I had a 2012, when it was 7 years old it had the front subframe off for the turbo drain mod, the corrosion was horrific, I would expect much better protection from the tin worm than JLR deem necessary. BMW i3 Electric Car
2nd May 2022 5:58pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 |
I had Raptor coating done after taking the rust off.
2nd May 2022 11:10pm |
I haven't checked the sills properly yet. As the consensus suggests, it should all be treatable etc. Thanks all ! |
3rd May 2022 4:49pm |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 453 |
Mine is a 2011 and there's nowhere near as much corrosion on mine as that one. It looks like surface stuff but even so, has it lived by the sea? Christian.
3rd May 2022 5:15pm |
Impressive work above.
21st May 2022 1:41pm |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
i use a lot of raptor coat it is a very hard wearing coat . but for a good coat of wax i have started using lanoguard you can cover every thing even exhaust so no masking about £50 for 2 ltrs and it covers well and seems to last easy to re fresh just cover brakes etc new vehicle purchase
21st May 2022 2:54pm |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 |
hey oggy. How much Lanogard does it take to do the underside? |
21st May 2022 4:52pm |
it goes a long way you would have a drop left if you got 2 ltrs . they also do a tub of grease that you use over more heavy parts that are rusty a lot of vids on you tube have a look oggy new vehicle purchase
21st May 2022 5:18pm |
