![]() | Home > Technical (L322) > 4.4 TDV8 egr pipe into intake |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 475 ![]() ![]() ![]() |
There should be an o ring that sits just inside the housing, no gasket. |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 351 ![]() ![]() ![]() |
Thought so There was no o ring just gunk best sort it out 2012 Range Rover Westminster 4.4 TDV8
Any idea on part number or where to get one 2012 Range Rover Westminster 4.4 TDV8
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2642 ![]() ![]() |
I didn't find one in mine but perhaps I didn't dig deep enough in the recess. However I recall that the pipe felt as though it was pushing through a seal. |
Not sure if this is your exact year ETC but if you look at the picture you can see where the O ring should fit. LR023038. |
