Home > Maintenance & Mods (L322) > TD6 noises
I8A Jeep
South Africa 2003 Range Rover HSE Td6 Buckingham Blue
TD6 noises
Hi all. I have two really irritating noisies on my 2003 TD6. When accelerating hard I start to get a metallic rattle from what sounds to be behind the steering weel / footwell area at around 3000 rpm - almost like loose bolts. However, I've had things apart, and cant find anything inside the car thats loose. Anyone had similar problems?
Second issue also relates to acceleration, I get a squeel, like the sound of a belt slipping, sometimes on acceleration, but only when doing things like overtaking. when I pull away hard, no squeel. I'm concerned its turbo related, but if it were, surely I'd have the problem on hard acceleration from a standing start?
I know diagnosing noises is very difficult without seeing the vehicle, but if anyone can offer some suggestions, it would be great!
Thanks.
Post #68471 14th Jun 2011 7:22am
Rangie in oz
United Kingdom 2003 Range Rover Vogue Td6 Epsom Green
not sure about the squeal unless its an intercooler pipe split, mine rubbed through on the big clip by the A/C commpressor, but the rattle could be a exhaust heat shield loose, they can make some odd noises.
good luck with it 03 TD6 vogue....Epsom, very nice
03 TD6 se....gone Sad
94 Vogue se....gone Sad
Post #68474 14th Jun 2011 7:29am
rattle, could be a loose cat in the exhaust. squeal might be a slipping belt..
Post #68482 14th Jun 2011 8:47am
I8A Jeep
Thanks for the ideas guys. If its a loose cat - can I just get that removed?
I hope the squeel is as simple as a loose belt, but I've checked the tension on the front drive belt and it seems fine - I would have expected it to squeel from a standing start if it were that though..
Post #68486 14th Jun 2011 8:52am
cats can be removed if thats acceptable for you mot's if you have them..
Post #68488 14th Jun 2011 8:54am
I8A Jeep
Thanks - no MOT's as such here, so sounds like the way to go.
Post #68489 14th Jun 2011 8:59am
