Home > In Car Electronics (L322) > Range Rover Ghost |
Darryl72 Member Since: 25 Oct 2016 Location: East Sussex Posts: 62 |
I've realised that if the airbag light is out my wipers work fine if that helps with diagnoses. |
30th Apr 2022 6:50am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
i would certainly look at the battery..it might be only a year old but the FF is very voltage sensitive.. ... - .- -.
30th Apr 2022 6:59am |
Thanks Stan, Id like to be the battery as its an easy fix rather than a needle in a hay stack!! |
1st May 2022 3:59pm |
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 |
B interested if you find out wat caused your heated drivers seat (rhd) go out mate. 😎🇦🇺 |
20th May 2022 7:37am |
My heated seat has started working again without any intervention....sort off......
18th Jun 2022 9:48am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
If it were mine I'd be looking at the BECM next, a few posts on here of them failing, they start with so called unrelated faults and actions...
18th Jun 2022 10:36am |
Hey Darryl, my 02 had similar problems so i fitted new battery with no good results…..put scanner on and found i have fault with interior lights, car doesn’t unlock from key fob, rain sensor not working, drivers seat heat doesn’t work (all other seats work), and other things not working i just can’t think of at the moment….scanner on and this all comes up with BCM under left seat is in transport Mode…..sound similar? |
18th Jun 2022 5:31pm |
It is pointing that way! Also my brake lights stay on whilst the air bag is half aluminated! Did replacement fix your problems? |
24th Jun 2022 3:27pm |
No, i did a scanner reset on the BCM and all functions are working correctly except the auto rain sensor which i’ll deal with another day.
24th Jun 2022 7:08pm |
So just in case someone in the future has something like this (hey its a RR so someones gonna need this!) I seem to of fixed the problem.....8 days clean!!, not sure which cured it but this is what I did, new battery did not make a difference this time, took off three earth points under the bonnet, cleaned and refitted, removed and cleaned all fuses under the bonnet, glove box and boot, removed all ebox internal connections clean replaced, removed plugs from BCM under passenger seat cleaned replaced, wd40'd the key ignition, all were clean with can electrical spray and battery disconnected.
6th Jul 2022 6:57pm |
That’s great news Darryl, how long or how many miles have you travelled without problems popping up?
6th Jul 2022 9:06pm |
There is a LR approved contact treatment - Nyogel, it works by having a high dielectric strength and a high viscosity which prevents moisture ingress and contact fretting. It's not particularly cheap but it does work very well. a company called Newgate Simms sell it in UK, ~£30 for a 25g tube. |
6th Jul 2022 10:07pm |
Hi Googs,
7th Jul 2022 6:50pm |
Wow great news Darryl, lets hope it keeps up.
7th Jul 2022 8:00pm |
