![]() | Home > Technical (L322) > Air suspension compressor |
Skeletor Member Since: 06 Apr 2019 Location: Cornwall Posts: 18 ![]() ![]() ![]() |
Having an issue when I pump the suspension height up and down a few times it’s saying ‘normal height only’ plugged in the GAP and it shows compressor slow to fill.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3258 ![]() ![]() ![]() |
Here is best https://www.bagpipingandy.com/
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Also depends on what compressor you have as too wether you can do a rebuild on it some you cannot? I bought a kit from bagpipe and had to send it back. |
Ok thanks I’ll give them a try |
mark towill Member Since: 27 Aug 2020 Location: calgary Posts: 19 ![]() ![]() ![]() |
The competition is 4x4AirSeals Hitachi or Dunlop Land Rover compressor rebuild |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6766 ![]() ![]() ![]() |
I had that error and it turned out to be a hole on the air reservoir. I found this out after replacing the compressor, twice |
