Home > Technical (L322) > Air suspension compressor |
Skeletor Member Since: 06 Apr 2019 Location: Cornwall Posts: 18 |
Having an issue when I pump the suspension height up and down a few times it’s saying ‘normal height only’ plugged in the GAP and it shows compressor slow to fill.
26th Apr 2022 12:16pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
Here is best https://www.bagpipingandy.com/
26th Apr 2022 1:40pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1188 |
Also depends on what compressor you have as too wether you can do a rebuild on it some you cannot? I bought a kit from bagpipe and had to send it back. |
26th Apr 2022 2:23pm |
Ok thanks I’ll give them a try |
26th Apr 2022 2:48pm |
mark towill Member Since: 27 Aug 2020 Location: calgary Posts: 19 |
The competition is 4x4AirSeals Hitachi or Dunlop Land Rover compressor rebuild |
28th Apr 2022 3:57am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
I had that error and it turned out to be a hole on the air reservoir. I found this out after replacing the compressor, twice Got - 2017 SDV8 Autobiography in Loire Blue
28th Apr 2022 5:46am |
