Home > In Car Electronics (L322) > Audio
David j
Wales 2006 Range Rover Vogue Td6 Zambezi Silver
Audio
Hi I am a new member.my name is David.I have a try l322 vogue.It has lost the sound on the rear door speakers.Can any one help.
Post #629275 21st Apr 2022 5:33am
I would start by unplugging all the connections to the dsp unit in the passenger side boot compartment and check for corrosion. The dsp unit is the large black box rearmost with the plug connections on the top. In particular check the plug nearest the centre of the car. This plug is all the speaker feeds in from the radio / amp unit and out to the speakers.
It’s not unknown for these connections to cause problems. Thumbs Up
Post #629306 21st Apr 2022 12:27pm
David j
Hi should have mentioned my car is an 06 which is fitted with a logic 7 amp. Not the DSP.
Post #629308 21st Apr 2022 1:01pm
So it is. Embarassed
Post #629312 21st Apr 2022 1:58pm
