![]() | Home > In Car Electronics (L322) > Audio |
I would start by unplugging all the connections to the dsp unit in the passenger side boot compartment and check for corrosion. The dsp unit is the large black box rearmost with the plug connections on the top. In particular check the plug nearest the centre of the car. This plug is all the speaker feeds in from the radio / amp unit and out to the speakers.
David j Member Since: 20 Apr 2022 Location: Ynysybwl Posts: 2 ![]() ![]() ![]() |
Hi should have mentioned my car is an 06 which is fitted with a logic 7 amp. Not the DSP. |
So it is. |
