Home > Maintenance & Mods (L405) > 2017 L405 TDV6 Brembo 6-pot brake upgrade?
Page 1 of 3 123>
Gremlin500
Hi, I have the size “19” brakes TRW sliding calipers with the smaller 360mm front discs. All 4 discs need replacing and the calipers are a bit grotty to say the least, so I was thinking is it possible to use these and those:
https://www.ebay.co.uk/itm/175069389808
https://www.ebay.co.uk/itm/264868412222
i.e. would it be a straight swap, all four corners?
The calipers are £1250 with no exchange possible, of course.
I’m not interested to know if I should, just if it would all fit OK, as obviously £1850 is a lot to spend on paperweights Laughing
Appreciate some good tech advice, I’m a bit concerned about the different diameters and possible disc offset, brake hose length/position, etc. Bow down “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #628470 12th Apr 2022 5:13pm
Gremlin500
Ooooops! Can I answer my own question? Laughing
This:
I hope it helps others with similar spendthrift OCD tendencies….. Mr. Green
Going to pull the trigger(s) tomorrow on these, pray for me tonight, promise I will do a write-up when I do it…… Idea “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #628495 12th Apr 2022 8:06pm
Gremlin500
OK, so I ordered the bits and calipers already delivered in 24h, very nice paint finish. I have worked with big industrial brakes, including Brembo, for more than 35 years, so can say these defo are original (refurb) castings, some minor paint overspray on new seals needs removal, ideally castings should be masked/blanked before installing pistons/seals/painting, but otherwise generally pleased.
Discs and pads arrive next week. Will do a full write-up on here when I do the work. Watch this space….. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #628695 14th Apr 2022 10:15pm
Gremlin, check what quality the brake pads are when they are delivered, sir...
Search Brembo brake pads on here if you've not done so already sir... Thumbs Up
Post #628698 15th Apr 2022 12:02am
Gremlin500
Hi Craig,
Thank you, yes I am aware of the presence of fake CN brake pads, (and even brakes!). At work we sell similar brakes for wind turbines and the like, so yes caution is advised as you suggest. Will brake balance F/R be affected, or is that smoke & mirrors? It would be good to calculate the area of 6-pot vs 2-pot to see the difference in clamping force, (maybe its actually not much different I suspect). Yes, the linings are larger, however friction is independent of surface area, so all that does is improve lining life, and NOT friction performance, as some folks wrongly think. Yellow Stuff pads seem well recommended for everyday driving? “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #628702 15th Apr 2022 6:32am
Mikey
Yellows are OK. Still had them fade on my Disco 3, but there's a whole lot more weight in that, and we were *pushing on* somewhat Laughing
Post #628703 15th Apr 2022 7:07am
Gremlin500
Thanks Mikey, the answer is probably somewhere on here already but I’m in lazy mode Embarassed
what is the difference between red/green/yellow? I am thinking yellow are softer with more CoF so require less effort but wear faster, or am I wrong? Rolling Eyes I’ve not used these so appreciate advice from someone who has. Bow down
After splashing out nearly £2K on brakes/discs, I don’t want to skimp on pads, even if I’m not really a “press on” kind of driver, I prefer to enjoy the tranquil experience that is the FF, partly why I opted for the V6, which has a lazier delivery and seems to suit the car well, so I’d like to choose friction on a similar basis, I don’t tow or carry much weight, I have a pickup for the heavy stuff, our largest brake calipers by the way are over 900kg each and produce 555kN each side of the disc Shocked “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #628714 15th Apr 2022 11:05am
Gremlin500
Sorry, another request please, but I’m on a steep learning curve here. There is some minor corrosion on the brake pipe fittings, so I was thinking about renewing the flexibles all round while I’m on (MY2017) does anyone know the LR part numbers for these and the best place to obtain at a decent price? Bow down
Is it true that LR recommend replacing these every 6 years? “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #628715 15th Apr 2022 11:15am
Kot
https://osh.landrover.com
input your VIN and look up 6Y schedule, for MY18 it is every 6y to replace flexible hoses. 2018 SE SDV8 4.4 Byron Blue
Post #628717 15th Apr 2022 11:51am
Gremlin500
Thanks Kot, so I may as well do it in that case, makes sense. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #628719 15th Apr 2022 12:15pm
Mikey
Greens are the lower end of the range, more road based. Used them on lighter stuff, and been fine
Reds were my pad of choice, but having used them in my D3, I took them out after only a few thousand miles, and have now been discontinued for this Range
Yellow pads work at a higher temperature range than greens, ideal for what I need them for, but can be a little dusty
Post #628720 15th Apr 2022 12:22pm
pld118
Greens been A1 on our TDv6 for 3 years and 30k miles… fronts just been replaced.
Rears still going strong. Ours is a daily driver around town, on motorways across the country and has towed a heavy trailer. 3.0 TDv6 is no sports car so on that basis, not sure what brake pads could be better…
No noteworthy brake dust.
Post #628739 15th Apr 2022 7:20pm
Gremlin500
Thanks Gentlemen, thats well corroborated, much obliged. Bow down
I’ll get some greens on order, are there any good deals to be had at the mo’ does anyone know? “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #628740 15th Apr 2022 7:26pm
pld118
Look forward to seeing your RR on the forum Gremlin (aka “Phil”)?
Post #628754 16th Apr 2022 6:17am
Gremlin500
Very Happy
Hi pld118, no I’ve not posted any pics yet by intent, because I plan a few upgrades soon and want to post after those, “be patient, you must”, lol Whistle
“Gremlin500” comes from TVR forums way back, when I had a Griffith 500 which I called “Gremlin” for obvious reasons.
The huge heat from the 5.0 V8 tends to fry the electricals, resulting in spurious legendary electrical faults. I seemed to spend more time on the train to Newcastle (from TVR dealer in Hexham) than I did driving the car, which was an absolute money pit. I do hope keeping the name isn’t tempting fate tho’ Rolling with laughter
Thanks for your interest! Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #628756 16th Apr 2022 6:33am
Page 1 of 3 123>
