![]() | Home > Maintenance & Mods (L405) > 2017 L405 TDV6 Brembo 6-pot brake upgrade? |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1681 ![]() ![]() ![]() |
Hi, I have the size “19” brakes TRW sliding calipers with the smaller 360mm front discs. All 4 discs need replacing and the calipers are a bit grotty to say the least, so I was thinking is it possible to use these and those:
OK, so I ordered the bits and calipers already delivered in 24h, very nice paint finish. I have worked with big industrial brakes, including Brembo, for more than 35 years, so can say these defo are original (refurb) castings, some minor paint overspray on new seals needs removal, ideally castings should be masked/blanked before installing pistons/seals/painting, but otherwise generally pleased.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Gremlin, check what quality the brake pads are when they are delivered, sir...
Hi Craig,
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1815 ![]() ![]() |
Yellows are OK. Still had them fade on my Disco 3, but there's a whole lot more weight in that, and we were *pushing on* somewhat |
Thanks Mikey, the answer is probably somewhere on here already but I’m in lazy mode |
Sorry, another request please, but I’m on a steep learning curve here. There is some minor corrosion on the brake pipe fittings, so I was thinking about renewing the flexibles all round while I’m on (MY2017) does anyone know the LR part numbers for these and the best place to obtain at a decent price? |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1318 ![]() ![]() |
https://osh.landrover.com
Thanks Kot, so I may as well do it in that case, makes sense. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
Greens are the lower end of the range, more road based. Used them on lighter stuff, and been fine
Greens been A1 on our TDv6 for 3 years and 30k miles… fronts just been replaced.
Thanks Gentlemen, thats well corroborated, much obliged. |
Look forward to seeing your RR on the forum Gremlin (aka “Phil”)?
