Home > Technical (L322) > My First 'Restricted Performance' Warning
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
After nearly a year of (mostly) trouble free ownership, 'Restricted Performance' has eventually caught up with me. Popped up on the display yesterday after 20 miles or so on motorway and B roads. No noticeable drop in performance, but to be on the safe side pulled over and plugged in my trusty IID Tool. The only engine related fault was 'water in fuel'. Could this be related to restricted performance? I cleared the fault and the car has been fine since. The 'water in fuel' has come up twice before, but only when splashing through moderately deep puddles - I put this down to a dodgy connection or sensor, which seems to be a common problem.
Any advice appreciated. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #627223 29th Mar 2022 4:39pm
its probably water in the fuel filter...theres a release valve at the bottom or a better solution would be to replace the filter.. ... - .- -.
Post #627232 29th Mar 2022 5:33pm
rjff
That fault came and went as it felt liike it on mine and gave restricted performance with no noticible effect. Cleared usualy after a restart.
As Stan says, worth changing the fuel filter
On mine checked the water drain and found none but changed the filter and cleaned up the housing connector for the sensor. Came back occaisionally until a change of sensor.
HTH Cheers
Richard
Gap IIDBT
Post #627251 29th Mar 2022 8:05pm
wayneg
When I purchased my 3.6 TDV8 the seller advised of phantom fuel in warning messages and had a dealer bill to investigate. The dealer advised new filter housing was needed at big $$ and changed the filter. I got sick of the random messages pretty quickly and just unplugged the main filter housing plug. No more warnings and no errors. The WIF sensor is not a separate part. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #627283 30th Mar 2022 2:41am
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
It's quite common for the sensor to go bad I had to replace mine for the same reason.
The Restricted Performance message would pop up more and more frequently until finally it irritated me enough to buy a new sensor.
You can buy the sensor separately to the housing, although it seems to be a bit tricky to find. I got mine from Maltings. 2010 4.4 TDV8 Vogue SE
Post #627314 30th Mar 2022 10:29am
RR2B
Thanks everyone for the helpful advice. Service coming up next month, so I'll get my indie to change the filter and check out the connectors. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #627338 30th Mar 2022 2:22pm
jackie-o
Netherlands
I´ve had this both on Disco 4 and RR 4.4 TDV8. The water in fuel sensor goes bad. Getting a new sensor with new fuel filter housing seems to be the remedy (they are sold under 1 part number).
Good luck!
//J RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #627341 30th Mar 2022 2:51pm
