Home > Technical (L322) > My First 'Restricted Performance' Warning |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
its probably water in the fuel filter...theres a release valve at the bottom or a better solution would be to replace the filter.. ... - .- -.
29th Mar 2022 5:33pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
That fault came and went as it felt liike it on mine and gave restricted performance with no noticible effect. Cleared usualy after a restart.
29th Mar 2022 8:05pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
When I purchased my 3.6 TDV8 the seller advised of phantom fuel in warning messages and had a dealer bill to investigate. The dealer advised new filter housing was needed at big $$ and changed the filter. I got sick of the random messages pretty quickly and just unplugged the main filter housing plug. No more warnings and no errors. The WIF sensor is not a separate part. 2007 TDV8 VSE
30th Mar 2022 2:41am |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 |
It's quite common for the sensor to go bad I had to replace mine for the same reason.
30th Mar 2022 10:29am |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 251 |
Thanks everyone for the helpful advice. Service coming up next month, so I'll get my indie to change the filter and check out the connectors. 2011MY 4.4TDV8 Autobiography Baltic Blue
30th Mar 2022 2:22pm |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 |
I´ve had this both on Disco 4 and RR 4.4 TDV8. The water in fuel sensor goes bad. Getting a new sensor with new fuel filter housing seems to be the remedy (they are sold under 1 part number).
30th Mar 2022 2:51pm |
