Home > Maintenance & Mods (L322) > 4 new shocks required - any advice
kenneally_mark
Ireland 2012 Range Rover Westminster 4.4 V8 Santorini Black
Hi All,
I need four new shocks for my 2012 4.4tdv8 Westminster.
Any advice on which brand to go for and part numbers etc?
Also how easy/ difficult are they to fit?
Thanks, Mark
Post #627195 29th Mar 2022 1:26pm
why do you need four Mark? ... - .- -.
Post #627196 29th Mar 2022 1:33pm
kenneally_mark
It failed three on the DOE (MOT equiv) so I just said I'd do the four. He said three are leaking....
Post #627197 29th Mar 2022 1:51pm
Mr Tee
best i found was forum sponsor duckworths tbh
Post #627201 29th Mar 2022 2:12pm
aids22
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Rimini Red
It is a common issue especially with the rear ones leaking.
If they still work ok I would wipe them down and take it to another MOT tester.
Post #627202 29th Mar 2022 2:13pm
replacing all four makes sense then..try our site sponsor 'duckworths' ... - .- -.
Post #627203 29th Mar 2022 2:13pm
mjdronfield
Misting is normal for the CVD shocks, but a proper leak obviously isn’t.
I know there tends to be a cheaper brand version, think it starts with A, and Bilstein ones…. Or LR ones, which I think might be Bilstein anyway.
Island 4x4 had an offer on rears recently.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #627205 29th Mar 2022 2:16pm
mjdronfield
Pretty sure these will be the cheapest, for Bilstein rears…
https://www.island-4x4.co.uk/suspension-pa...mp;sort=3a
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #627207 29th Mar 2022 2:21pm
kenneally_mark
Wow thanks for all the replies.
Can I get the front's without the bags or do I have to replace the two together?
Thanks
Post #627208 29th Mar 2022 2:25pm
JayGee
I'd clean the rears and retest as there is a LR workshop advisory note that says they leak but with no detrimental effect on performance. Fronts need replacing and I'd do it in pairs if I was you. AFAIK you can change the air bags on their own but not the shocks. How many miles? 2012 TDV8 Vogue (L322)
Post #627245 29th Mar 2022 8:23pm
dhallworth
When I changed the fronts on my 2007 car I decided to buy the ones with air bags on them.
The rubber on the airbags will now be 10 years old on the newest of L322’s so doing the bags and struts together will stop any problems with them not sealing properly and will save you having to strip it twice when the airbags give up in the future. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #627259 29th Mar 2022 9:27pm
DrRob
Site sponsor Advanced Factors.
Don't forget discount code Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #627262 29th Mar 2022 9:45pm
Another + for cleaning & retesting sir... Thumbs Up
Post #627276 29th Mar 2022 11:06pm
kenneally_mark
So the funny thing is the tester I went to has a reputation for not liking Land Rovers....
When I got home I checked the S/H and the front right bad & shock was changed in Nov before I bought it and he put that as one that was very bad.
I'm going to get these checked out elsewhere before jumping ahead.
Thanks for the advice / help but I did get a shock yesterday as it drives very well and I never saw them weeping.
I'll update this post after next Wed when I get it checked out. Thanks again
Post #627295 30th Mar 2022 9:21am
JayGee
In the UK a leaking shock is an MOT fail even if it's working properly. My rears are leaking but the rear end is not under damped and bouncing around so they are working fine. Was the replaced shock a LR part or a 3rd party make? 2012 TDV8 Vogue (L322)
Post #627298 30th Mar 2022 9:25am
