![]() | Home > Maintenance & Mods (L322) > 4 new shocks required - any advice |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
why do you need four Mark? ... - .- -.
kenneally_mark Member Since: 09 Jun 2021 Location: Cork Posts: 74 ![]() ![]() ![]() |
It failed three on the DOE (MOT equiv) so I just said I'd do the four. He said three are leaking.... |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2665 ![]() ![]() |
best i found was forum sponsor duckworths tbh |
aids22 Member Since: 10 Jun 2019 Location: Warrington Posts: 27 ![]() ![]() ![]() |
It is a common issue especially with the rear ones leaking.
replacing all four makes sense then..try our site sponsor 'duckworths' ... - .- -.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Misting is normal for the CVD shocks, but a proper leak obviously isn’t.
Pretty sure these will be the cheapest, for Bilstein rears…
Wow thanks for all the replies.
I'd clean the rears and retest as there is a LR workshop advisory note that says they leak but with no detrimental effect on performance. Fronts need replacing and I'd do it in pairs if I was you. AFAIK you can change the air bags on their own but not the shocks. How many miles? 2012 TDV8 Vogue (L322) |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3149 ![]() ![]() ![]() |
When I changed the fronts on my 2007 car I decided to buy the ones with air bags on them.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4321 ![]() ![]() ![]() |
Site sponsor Advanced Factors.
Another + for cleaning & retesting sir... |
So the funny thing is the tester I went to has a reputation for not liking Land Rovers....
In the UK a leaking shock is an MOT fail even if it's working properly. My rears are leaking but the rear end is not under damped and bouncing around so they are working fine. Was the replaced shock a LR part or a 3rd party make? 2012 TDV8 Vogue (L322) |
