Home > Technical (L405) > fridge operation
M11buc
United Kingdom 2019 Range Rover Autobiography SDV8 Santorini Black
fridge operation
Does any one how the if there is a reset for the fridge
handbook says it should work like this:
press once- one blue led lights up, on, low power
press twice- two blue leds light up, on, full power
press three times- no led lights up, fridge now off.
Post #626883 24th Mar 2022 8:51am
M11buc
Update. I managed to get to bottom of this issue. If any one else comes across it.
It turned out that. You can I have either a cooler box or a fridge fitted ( the fridge been specified as upgrade option upon build)
The cooler box has one setting on / off. The fridge has, on, off and low setting. They both look very similar (same button with two blue leds switch) however if you look closely inside the box the fridge lights up inside but cooler box does not.
If you have cooler box you can retro fit a fridge. The wiring is the same , just plug and play. Just remover cooler box and put fridge straight in the hole. All fixing are the same.
Post #667670 27th Jun 2023 2:32am
TomekW
Poland 2019 Range Rover Autobiography 5.0 SC V8 Indus Silver
Hello,
My L405 does not have cooler/fridge and I am considering to retrofit one.
I did it previously in my Discovery 4 so I thought it shall be pretty similar for FFRR....
I bought the second hand cooler box for L405 but now I struggling how to fit it.
It looks that I need either to cut the console trim or source the trim from donor L405 with cooler mounted.
Would you be so king and post couple of pictures how the cooler/fridge sits in the center console?
TIA.
Or maybe anyone has an experience with retrofit?
Post #668698 8th Jul 2023 9:29pm
Ryanmt
United Kingdom 2017 Range Rover Autobiography SDV6 Santorini Black
That's interesting. The pre 2018MY only came with the peltier cooler option. Pretty neat the facelift had the option of a real fridge with a proper compressor. I wonder if the facelift centre console or just the cooler unit can be retrofitted to the earlier cars?
Post #668822 10th Jul 2023 5:36pm
Beavis
United Kingdom 2017 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Has anyone tried this? My pre facelft cooler has stopped working, so wondering if it can be upgraded with the later fridge...
Post #692780 16th May 2024 12:51pm
