![]() | Home > Technical (L405) > Front Seat Massage |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 239 ![]() ![]() ![]() |
The Drivers Seat Module is located under the seat. If you remove it, you can get the part number and find one on ebay.
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 471 ![]() ![]() ![]() |
so I was at the garage today. It is the Lumbar Support - Land-Rover (LR101122). I have searched on ebay but found none. Other ideas where I can look for a second-hand part?
If it was me, I would start swapping parts between the seats to determine if that is the cause. The parts may be the opposite, but plugging them in will test functionality. Then you can confirm the actual part number of the item in your seat.
So looking at the links. The second link is for the pre-facelift model.
That is why I suggest finding the part number yourself. The plastic seat back comes off extremely easy.
