Home > Technical (L405) > Front Seat Massage
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Front Seat Massage
So over a year ago, the driver's seat massage stopped working. The garage checked and says it need a new controller. This will be fixed under warranty. The controller is still on order.
I miss this function on longer journeys. Would I be mad to see if I could try and find this part secondhand? Then get the garage to fit, and then replace it with the real part when it is available again.
Also, where can I find the part number? I will try and ask the service rep when the car is in for the replacement DPF. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #626499 19th Mar 2022 5:43pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
The Drivers Seat Module is located under the seat. If you remove it, you can get the part number and find one on ebay.
 Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #626547 20th Mar 2022 5:03pm
luxmoggy
so I was at the garage today. It is the Lumbar Support - Land-Rover (LR101122). I have searched on ebay but found none. Other ideas where I can look for a second-hand part?
The garage has no idea when the part will come and be fitted under warranty, it has been nearly a year now. SDV8 AB MY 2020
Post #627226 29th Mar 2022 4:58pm
Bora20
If it was me, I would start swapping parts between the seats to determine if that is the cause. The parts may be the opposite, but plugging them in will test functionality. Then you can confirm the actual part number of the item in your seat.
The part number you provided does not seem to be for massaging seats, only heated and cooled.
https://landrover.lakeridgeparts.com/p/71973957/LR101122.html
LR050252 looks like the same item, but for the massaging seat.
https://landrover.lakeridgeparts.com/p/Lan...50252.html
You could find a used seat on eBay or at local breakers and swap the seat cover (leather) if it is the wrong colour.
An internet search will find the part too:
https://www.german-spare-parts.net/massage...39019.html Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #627228 29th Mar 2022 5:11pm
luxmoggy
So looking at the links. The second link is for the pre-facelift model.
I will need to ask the garage again.
But looking at all of the US Range Rover 2019-2020 using that link, none seem to have got Massage seats.
It could be that the diagram is wrong. SDV8 AB MY 2020
Post #627235 29th Mar 2022 5:54pm
Bora20
That is why I suggest finding the part number yourself. The plastic seat back comes off extremely easy.
Likely the 2018-2022 years use the same part number for the internal massage components. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #627236 29th Mar 2022 6:02pm
