![]() | Home > Technical (L405) > Brake Caliper Rewind Toolkit (Caliper Piston) |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
I have one of those kits, it is in my "Tool Hall of Fame". Especially handy for cars with rear brake calipers where the piston is "threaded" on the handbrake mechanism .
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 473 ![]() ![]() ![]() |
Be careful on the L405 rear brakes, the calliper must be rewound using a diagnostic box via the OBD port as the handbrake is electronic, forcing the piston back using any other tool will break the mechanism resulting in costly repair. The piston can only be pushed back once the handbrake mechanism has been wound back using the correct method |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3811 ![]() ![]() ![]() |
Dave,
Just push them back on yours Mike as the handbrake is in the drum on the L322, it was changed on the L405 for an electronic motor on the calliper |
Thanks Dave, I thought that was the case, but grateful for your confirmation.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 773 ![]() ![]() ![]() |
I also have one of those kits. Well, it looks exactly the same but unbranded and about £12 from eBay |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
^ wot he said. Does work, had to do it to change the rear pads. There is nothing that can't be fixed with a hammer😜😜
