Home > Technical (L405) > Brake Caliper Rewind Toolkit (Caliper Piston)
pld118
Our 2014 MY Tdv6 L405 has TRW brake calipers all round. When changing brake pads or discs, the caliper pistons can’t be pushed back in by hand - unless your name is Bruce Banner Laughing
A one handed G-clamp / quick clamp with an old brake pad over the piston that is being pushed back in works:
If you’re interested in buying a tool(s) specifically designed for the job, you could do worse than buy this kit, especially if you’re likely to do more than one vehicle:
Hilka 21 piece brake caliper rewind tool kit - available from Screwfix/ can be bought cheaper elsewhere. Tools feel weighty, well made and kit includes magnetic adaptor plates (ie round metal plates to cover and push back the piston ring). Amongst the numerous plates is a 60mm plate that nicely covers our TDv6 piston ring. It’s an easy to use and effective kit (you can Google these type kits and watch a brief how to video if needed).
Recommended. Hope this helps someone as had to ask nmj about what tool he uses/ was never quite sure before that, despite searching the forum Thumbs Up
Post #625932 11th Mar 2022 7:47am
I have one of those kits, it is in my "Tool Hall of Fame". Especially handy for cars with rear brake calipers where the piston is "threaded" on the handbrake mechanism .
Post #625940 11th Mar 2022 10:43am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Be careful on the L405 rear brakes, the calliper must be rewound using a diagnostic box via the OBD port as the handbrake is electronic, forcing the piston back using any other tool will break the mechanism resulting in costly repair. The piston can only be pushed back once the handbrake mechanism has been wound back using the correct method Thumbs Up
Post #625963 11th Mar 2022 6:08pm
Baltic Blue
Dave,
Are their any similar issues with my 2011 ,L322 or is it safe to just force them back ??
Post #625965 11th Mar 2022 6:24pm
diesel Dave
Just push them back on yours Mike as the handbrake is in the drum on the L322, it was changed on the L405 for an electronic motor on the calliper Wink
Post #625966 11th Mar 2022 6:40pm
Baltic Blue
Thanks Dave, I thought that was the case, but grateful for your confirmation.
Post #625967 11th Mar 2022 7:01pm
knwatkins
I also have one of those kits. Well, it looks exactly the same but unbranded and about £12 from eBay Wink
You can also put the parking break into service mode without a diagnostic tool by doing the following...
1. Press and hold the parking brake switch in the release position.
2. Wait 2 seconds.
3. Press and hold the accelerator pedal in the wide open throttle position.
4. Wait 2 seconds.
5. Turn the ignition Off and back On immediately. An audible noise will be heard to confirm that the parking brake has been released in Service Mode.
6. Release the accelerator pedal and release the parking brake switch to the neutral position. An audible noise will be heard to confirm that the parking brake has been released in Service Mode
And to remove from service mode...
7. Press and hold the parking brake switch in the apply position.
8. Wait 2 seconds
9. Press and hold the accelerator pedal in the wide open throttle position.
10. Wait 2 seconds.
11. Turn the ignition Off and back On immediately. An audible noise will be heard to confirm that the parking brake has
been released from the Service Mode.
12. Release the accelerator pedal and release the parking brake switch to the neutral position. An audible noise will be heard to confirm that the parking brake has been released from the Service Mode Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #625970 11th Mar 2022 8:30pm
^ wot he said. Does work, had to do it to change the rear pads. There is nothing that can't be fixed with a hammer😜😜
Post #626083 13th Mar 2022 4:32pm
