![]() | Home > Maintenance & Mods (L322) > 2007 rear wheel getting warm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7866 ![]() ![]() ![]() |
Wheel bearing?
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 753 ![]() ![]() |
could it be rust under the shims that the pads slide on? |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Were the caliper slide pins moving ok? The upper pin has a rubber boot part way down that can swell and cause the pin to jam 2011 TDV8 Vogue SE |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 904 ![]() ![]() ![]() |
I'd still put money on it being a sticky calliper.
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 453 ![]() ![]() ![]() |
The wheel bearing would have to be close to collapse to generate enough friction to warm the wheel.
tdv8rr2007 Member Since: 26 Oct 2021 Location: Yorkshire Posts: 13 ![]() ![]() ![]() |
All valid points thank you! However both pins were free as anything, and i always take the shims off and thoroughly clean under them them when changing pads.
Ah, forget the wheel bearing then….
If you don’t find anything else it could be the flexible brake hose at fault. They have been known to deteriorate internally and end up acting as a non return valve. |
If i remember correctly the rears were done as a dealer recall approx. 5 years ago. I would be disappointed if genuine parts had failed in that time although its not impossible. Will stick a caliper on it and see if that cures it if not then I agree that pipe is indeed suspect. |
If you see any black bits in the bled brake fluid, that would indicate if the flexi hose was breaking down.
Good point Mike! Have parked the Rangie up till the weekend till i can get a caliper. Will be interesting to see what comes out. |
DanRRL322sc Member Since: 16 May 2022 Location: Bedfordshire Posts: 55 ![]() ![]() |
What was the outcome??? |
