Home > Maintenance & Mods (L322) > Difference between MAP and MAF sensors
Rambles
I get confused between the difference
And also maybe some folks might have meant one but typed the other
Can folks confirm what they do and where they are please ?
Thanks
Post #625524 6th Mar 2022 4:11pm
Baltic Blue
This is the sensor that requires most regularly cleaning, I clean mine every 6 months at the same time as I am changing the oil and filter.
It’s full name is the Manifold Absolute Pressure and Temperature sensor, (MAPT) Sensor.
Post #625527 6th Mar 2022 4:43pm
Baltic Blue
There are 2 M.A.F sensors ( Mass Airflow Sensors ) , one in each of the air filter ducting, that require less frequent inspection.
Mike
Post #625534 6th Mar 2022 5:18pm
JayGee
MAP sensors measure intake pressure ( absolute pressure and not relative to weather or altitude). MAF sensors measure air mass (not volume so it's temperature and pressure independent) entering the intake. One map sensor and a MAF on each intake. Both are used to calculate fuelling, boost and identify any faults ( leaks) if they present unexpected data to the ECU. MAP sensor needs regular cleaning as it's position mean it's getting soot from the EGR which can make it slow to respond to throttle pedal input ( hesitation) . MAF sensors shouldn't need any work as they just get clean air. There is also an AIT sensor before the throttle which measures the intake temperature post turbo and IC. 2012 TDV8 Vogue (L322)
Post #625544 6th Mar 2022 6:48pm
Rambles
Is there a recommended way of cleaning the sensors? Bit of brake cleaner ? Compressed air blast ?
Post #625614 7th Mar 2022 3:29pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
I used brake cleaner and worked a treat.
Post #625623 7th Mar 2022 4:48pm
