Home > My Range Rover > My New L322 2008 TDV8 Vogue |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 693 |
She sounds ok, a few photos wouldn’t go amiss!😜
7th Mar 2022 7:37am |
cb07 Member Since: 09 Feb 2022 Location: Hertfordshire Posts: 42 |
7th Mar 2022 7:41am |
Was struggling to use the upload yesterday!
7th Mar 2022 7:51am |
Looks nice!
7th Mar 2022 8:00am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3128 |
That’s a nice looking car
7th Mar 2022 11:16pm |
Had a bit of a nose around under the panel to see what was going on. Some one has been there before because the clips are all a bit mangled. however the pump/area surrounding it is dry, no water etc in there and the pump housing looks quite new.
8th Mar 2022 7:53am |
Travall dog guard and rubber mat added!
12th Mar 2022 1:48pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3778 |
The rear screen washer on mine kept blocking until I bought one of these plastic syringe and flushed out the pipes with hot water.. If you disconnect the pipe at the one way valve you can force hot water both ways until it is flowing freely, either sucking fluid from the tank or through to the nozzle.
12th Mar 2022 4:39pm |
Drivers headlight bulb went. Fitted a new pair of osrams and still was out. Panicked a little, did some digging about on here then ordered a new ballast!
26th Mar 2022 6:25am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8652 |
Nice. Pretty much the same as my first one. they are cracking cars, looking at the top turbo hoses in there they look quite original so might be worth a quick bit of preventative by swapping the top 2 hoses. There is nothing that can't be fixed with a hammer😜😜
26th Mar 2022 10:17am |
I’d hope not, given it’s done 150k. I’ll dig out the receipts as it had a full turbo/egr replace two years ago with a pretty mental bill. But since it looks like an easy job I’ll do it anyway as I gather from here they are basically consumable items. Cheers |
26th Mar 2022 10:26am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1234 |
I must say, that's a very clean engine bay. Nice. |
26th Mar 2022 11:48am |
yep. easy 15 min job...
26th Mar 2022 11:56am |
Transmission and gearbox fluid flushed. Runs very smoothly now!
2nd Apr 2022 6:26pm |
