Charmer
Firstly, are you going to do the work yourself or "entrust"it to a garage? If DIY I may be able to help depending on what you find.
When mine suffered the same symptoms, I was lucky enough to be able to run the tank rght down and undertake the repair myself.
My fault was the pump fell over in the tank, athough it remained operational. I carried out the TSB while in there.
The TSB you refer to does show only 2010-12 FFs but it may be yours has the same in tank inline connectors that need atention.
HTH Cheers
Richard
(there are no such things as an ordinary FullFat, an ordinary cat or too many tools)
2011 TDV8 Vogue Santorini Black
Gap IIDBT
