Home > Maintenance & Mods (L322) > 2nd Battery
Discofish
England 2003 Range Rover HSE Td6 Oslo Blue
2nd Battery
Morning all,
My great plan for a solar charger just doesn't seem to cut it so, does anyone have a wiring diagram for the 2nd battery in the boot?
I've seen a kit on e-bay which has a fuse, relay and some lengths of Red cable already 'screwed' together but at £100 it seems a bit steep (I know for a fact that I have all those bits lying around so all I need is instructions to build and fit one)
Cheers
Post #624967 28th Feb 2022 9:16am
Dolphinboy
do a search on here. there are several who have done their own.
Post #624980 28th Feb 2022 11:50am
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Today is Monday, I fitted this kit yesterday Sunday, with a 110ah battery into the right side towball void under the floor.
https://www.ebay.fr/itm/202528541127?_trkp...0667.m2042
I bought the ready assembled kit because in terms of time etc, it just seemed to make sense not to have to measure, cut, and make up cable ends.
Kit was perfect, instructions very clear, even included extra bits just in case.
I used one of the bumper bolts as the Earth point.
I did use both fuses as suggested ie before and after the relay, probably overkill but hey.
Located battery with the terminals inboard to aid access.
Just had to cut out a very small 1.5" section of the plastic tray that you cant even see, to clear the top of the +ve terminal bolt, and also trimmed down the rear captive bolt sticking up out of the floor in case it poked through the bottom of the battery.
The only fitting headache was physically lifting the 110ah battery in and out of the deep but narrow recess during the positioning process. Mighty heavy!!
All carpets and panels back in place, you would never know that a big battery was there.
Didn't bother with pictures because Joe90 and other threads give a good idea.
Best, Rich L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #625044 28th Feb 2022 9:13pm
wayneg
Had a look at that kit and it's a fair price for what is included. One thing you might want to consider is lifting the loom out of the well and routing it up and over the wing fusebox, I did this easily. My concern was the battery could possibly move over time with vibration and bumps then wear through the insulation. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #625048 1st Mar 2022 2:23am
Discofish
looks good, have got a split charger system on my Disco for the winch but that uses an ignition controlled relay as apposed to voltage sensing (as in that kit) so would need a suitable pick-up point on a fuse box if I went the same way (usually its a system that is 'Dead' during the engine start but then becomes 'live' once the engine is running)
Thanks for the info
Good point about the loom and just to be extra safe i'd make some form of clamp for the battery ( I know it effectively under the floor panel but you wouldn't want it hitting you on the back of the head if the worst happened Wink )
Post #625084 1st Mar 2022 2:03pm
from our wiki,
https://www.fullfatrr.com/forum/topic26065.html ... - .- -.
Post #625085 1st Mar 2022 2:29pm
darrenm
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Easy to do
Post #625179 2nd Mar 2022 7:18pm
