![]() | Home > Maintenance & Mods (L322) > Adaptive Dynamics Fault - Replacement Link Wire |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7868 ![]() ![]() ![]() |
So…. Got the good old Adaptive Dynamics Fault this morning.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4324 ![]() ![]() ![]() |
I had a kit fitted by Glenrands and it now looks factory fresh. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Hoping it’s a simple fix.
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Kit is the same wires from what I could see. Fitted one a couple of weeks ago. Initially repaired the original but it failed again 6 months later so bit the bullet |
Yeah. If it’s that I will just get it joined up as best I can and then order the kit.
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 331 ![]() ![]() |
The replacement front ones are a slightly better design when I compared them. i cant remember what precisely but I noted at the time they were more substantial. I think the rubber maybe onepiece when before it was two.
Cheers for that. Saw those when the rear shockers were replaced.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
let us know how it goes |
I also noted that the broken side didn’t have a gromit fitted, so each turn of the top would have pushed the wire directly…..
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2572 ![]() ![]() ![]() |
I released the clip holding the wire to the body to give the cable near the cap more freedom to move less. I also rotated the plate below the cap so that the cable had equal freedom when the cap turned in each direction. |
Fitted the new wiring. Fault has cleared from the dash and suspension no longer rock solid.
Mine stays quite flat initially but will start to lean a little on a long bend. I regularly travel a section of rural road that does an S bend over the top of a hill, starting at 100 kph then easing off a little over the crest. The vehicle is very steady, without lurching, understeer or oversteer as it changes direction through the bends. |
