Home > Maintenance & Mods (L405) > Powered Tailgate Not Closing - Now Resolved
it would be interesting to know how this sensor setup works...time to read the WM me thinks.. Laughing ... - .- -.
Post #623361 11th Feb 2022 10:39pm
JCW
To close this thread out, fitting the new anti-trap sensors (located in the trim on each side of the upper tailgate) didn’t resolve the issue.
However as the tailgate vertical alignment wasn’t great (as seems to be quite common) I decided to adjust it & also ordered the revised bolts that attach the hinges to the body (4x RGY501160). The only visual difference is the revised bolts are a 10mm head whereas the originals are a 13mm. The attached washer is the same size.
Apparently the original bolts on earlier MY’s are prone to ‘relaxing’ per the LR technical bulletin, and mine certainly didn’t seem particularly tight, the correct torque is 24nm.
I found the easiest method was to work on one side at a time, detach the power strut, remove the two nuts that attach the tailgate to the upper part of the hinge (you need to remove the spoiler to access these) then undo the two bolts holding the hinge to the body. This way, I could reposition the hinge in its upper most position without the weight of the tailgate pushing it down. I used a suitable length of timber to support the tailgate whilst the hinge / power strut was removed.
On reinstalling everything, hey presto, the power open & close is now working perfectly Very Happy
Hopefully helpful for others who may encounter a similar issue - worth sorting the alignment before buying any new parts Thumbs Up
Post #628120 8th Apr 2022 6:09pm
cager
United Arab Emirates 2017 Range Rover Vogue SE 5.0 SC V8 Santorini Black
RRV8SC wrote:
This worked for me! Thank you.
I had a new battery replaced and when I got it back the bottom would close but I would get the beep beep. I followed this procedure and it worked again.
From : https://www.fullfatrr.com/forum/topic60938.html
"Hi try pushing lower tailgate button and while it is trying to shut manually push lower tail gate shut.
Then push upper tailgate button to close upper tailgate.
Then use key to open tailgates as per normal.
This should put all back in right order.
give it a go hope that fixes it."
Post #695282 30th Jun 2024 8:36am
