Home > Maintenance & Mods (L322) > Rear Height Sensor
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Rear Height Sensor
I've tried to remove the two torx bolts so I can remove the sensor, they just spin around and around.
Anyone else had this issue and managed to get around it?
I need the sensor off to remove the bolt that holds the tie arm on. Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #622879 7th Feb 2022 5:11pm
Caesium
Sorted it now, if anyone is interested
I had to get the dremel out and cut the heads off. Then drilled and punched out the inserts with bolt thread still present.
Appears that the bolts are held by a captive thread insert in the plastic body which just spin around and around as the bolt has corroded to them.
I'll replace with M5 pan head bolts and nuts.
 Christian.
Current Cars
2019 BMW X4
or
Post #622956 8th Feb 2022 12:38pm
Caesium
Here's the refitted level sensor with nuts and bolts.
 Christian.
Current Cars
2019 BMW X4
or
Post #622971 8th Feb 2022 2:47pm
