Home > Technical (L405) > Noisy Fuel Pump
tomo141
Noisy Fuel Pump
Noisy Fuel Pump
Does anyone use a fuel additive for 4.4. MY18 has a noisy fuel pump, it has been suggested that i try a fuel additive.
It has been in main dealers 3 times and had a new fuel pump, sometime its' loud sometimes it's quiet. Dealer says that all 4.4's are the same as the pump sits just behind passengers footwell.
When its on tick over or driving slow in traffic you can hear the pump buzzing away which is so annoying. Apart from noisy pump it drives and runs like a dream.
I'm wondering if anyone has had a similar issue and if you use an additive and what type and if it made any difference. ------------------------------------------
L460 D350 73 24 model FFRR Autobiography Santorini Black with Shadow Pack
L405 4.4 V8 18 FFRR Autobiography (facelift) Santorini Black with Shadow Pack
L405 3.0 V6 13.5 FFRR Autobiography Santorini Black
L322 4.4 V8 12 FFRR Autobiography Santorini Black (RR Styling Pack)
L322 3.6 V8 10 FFRR Autobiography Santorini Black
L322 3.6 V8 07 FFRR Vogue SE Santorini Black
L322 3.0 I6 55 FFRR Autobiography Santorini Black
Post #622708 6th Feb 2022 12:01pm
knwatkins
I can't say I've heared it on mine. If the main dealers are saying it's on all 4.4s, you could ask them to show it to you on their forecourt vehicles. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #622719 6th Feb 2022 12:45pm
tomo141
Thanks. A friend has a 4.4 Sport and you can hear the fuel pump but you do haven't to listen for it. If mine was the same i could live with it.
The last time it was in MD they didn't have a 4.4 FF on the forecourt, several 3.0, It's not an issue with the 3.0. ------------------------------------------
Post #622768 6th Feb 2022 5:36pm
Astanavits
France
Like this ?
https://youtube.com/shorts/x1vBup9Neyg?si=U0CKZqD196xkX06w
Post #712105 18th Feb 2025 2:33am
Vogue
Never heard it on any of mine 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #712109 18th Feb 2025 4:18am
Astanavits
France
I post two video two different owner
https://www.fullfatrr.com/forum/topic72660.html
Post #712111 18th Feb 2025 4:23am
Astanavits
France
vogue would you be able to post a video of your engine please ?
Post #712113 18th Feb 2025 5:05am
niklasel
Sweden 2014 Range Rover Vogue SDV8 Causeway Grey
Hi - I started to hear my front pump just before it broke. It's not something you should be hearing. But, I shifted to an OEM one first and it was noisy right from the start. Ordered a genuine one and then the noise disappeared.
I think something is wrong with your car. It may be the in tank fuel pump. It can also relate to other parts like fuel pressure regulator making it need to pump more than necessary or the high pressure pump doing the same. Somehow your pump should not make noises.
Post #712230 19th Feb 2025 2:04pm
