![]() | Home > Technical (L405) > 2016 suspension knocking |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 463 ![]() ![]() ![]() |
Hi funny guy. It will be either the the lower arm bushes located in the front of the subframe, a favourite on these,( have changed mine) or the D bushes on the anti roll bar which is favourite n0 2. Which ever its not a massive issue and changing should stop the clunking.
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 387 ![]() ![]() |
Thanks Dave!! Much appreciated! |
Hi Dave, took car in and it was sway bar bushings. The knocking is gone! Best! Mike |
mlambton Member Since: 30 Sep 2021 Location: Devon Posts: 68 ![]() ![]() ![]() |
On my L322 I had to replace the ARB bushes every 2 years or 15k miles. The symptom that they had worn out was either a knock or it began to sound like a tank whilst driving slowly with even the slightest bump causing a squeak which was particularly noticeable in the drier months (no moisture on the bushes). 2015 Range Rover L405 SDV8 AB Corris grey
Great news Mike, nothing more annoying than a clunky suspension. |
