Home > Technical (L405) > 2016 suspension knocking
funnyguy1
United States
So I have the dreaded front suspension knocking at 20-25 mph. Sounds like its coming from right under the front pedals on both sides. I read pld118's LR notice on it and I don't believe its the valve block as they seem to have replaced it after 2013 so now suspecting the bushings. It goes in in 2 weeks but I was wondering if any other 2016 owners have experienced the same problem and if it was something else?? Thx
Post #622662 6th Feb 2022 3:22am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Hi funny guy. It will be either the the lower arm bushes located in the front of the subframe, a favourite on these,( have changed mine) or the D bushes on the anti roll bar which is favourite n0 2. Which ever its not a massive issue and changing should stop the clunking.
You can swap just the bushes but it’s actually easier to replace the whole arm Thumbs Up
Post #622778 6th Feb 2022 6:34pm
funnyguy1
United States
Thanks Dave!! Much appreciated!
Post #622815 7th Feb 2022 2:45am
funnyguy1
United States
Hi Dave, took car in and it was sway bar bushings. The knocking is gone! Best! Mike
Post #624047 18th Feb 2022 12:04am
mlambton
United Kingdom 2015 Range Rover Autobiography SDV8 Corris Grey
On my L322 I had to replace the ARB bushes every 2 years or 15k miles. The symptom that they had worn out was either a knock or it began to sound like a tank whilst driving slowly with even the slightest bump causing a squeak which was particularly noticeable in the drier months (no moisture on the bushes). 2015 Range Rover L405 SDV8 AB Corris grey
2010 Range Rover TDV6 HSE Narra Bronze sold
2006 Discovery 3 SE green sold
Defender 90 td5 sold
Defender 90 soft top sold
Post #624431 22nd Feb 2022 5:26pm
diesel Dave
Great news Mike, nothing more annoying than a clunky suspension.
Post #624451 22nd Feb 2022 10:19pm
