Home > Technical (L322) > Suspension not lowering to access height
Giffer2018
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
Hi guys,
When I press door or centre button to drop suspension from normal to access height, I get restriction message and it raises to extended height. It was previously working ok. The 4x4 info screen does not show any faults and there are no faults being recorded on Gap tool. Checked all the height sensors they look ok. Any ideas? -----------------------
RR Vogue 4.4 TDV8 2011 - Galway Green
Kia Sorento 2.5 CDi 2007 - Bright Silver
Post #622214 2nd Feb 2022 12:22pm
mjdronfield
Might not be this, but I’d remove the exhaust filter from the air suspension compressor and try again.
I had the same issue and it was due to the car not lowering fast enough, as it couldn’t get the air out.
No issues since. Garage wanted £700 to fit a new compressor…..
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #622220 2nd Feb 2022 1:10pm
mjdronfield
https://www.fullfatrr.com/forum/topic23038...ust+filter
https://www.fullfatrr.com/forum/topic4376....ust+filter 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #622222 2nd Feb 2022 1:20pm
Giffer2018
Thanks for that mj, will try that in next few days. -----------------------
Post #622235 2nd Feb 2022 3:49pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
You can clean the exhaust filter with some hot water. Don’t remove it permanently. It’s got a purpose. Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #622261 2nd Feb 2022 8:14pm
mjdronfield
I tried soaking mine in Petrol but it was still blocked. You could buy new ones for around £32 but not sure if you can now.
Drilled a hole in it and refitted.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #622266 2nd Feb 2022 8:35pm
Caesium
I just used hot water and an airline. Seemed to come up sparkling really easy Christian.
Current Cars
2019 BMW X4
or
Post #622267 2nd Feb 2022 8:36pm
Giffer2018
Thanks for that Caesium. -----------------------
Post #622355 3rd Feb 2022 4:49pm
Sandyt
+1 for the hole drilling did it about 6 years ago and still ok in fact after drilling it watched as it lowered and raised the car the amount of white powder that came out was interesting
Post #622468 4th Feb 2022 4:40pm
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Another +1 for hole in filter , sorted mine out 5 years ago and still working fine .
Post #623169 10th Feb 2022 3:36pm
Giffer2018
Hi chaps,
removed compressor filter today, started it up suspension lowered to access height no problem. So have drilled a hole in filter and now refitted it. All I need now is the spare wheel lifting tool as I now know how awkward it is to get out.
Thanks a lot for your help and suggestions. -----------------------
Post #623185 10th Feb 2022 5:47pm
mjdronfield
Excellent. Saved about £700 there 🤣.
Yes, if I’d had known the later cars didn’t have the lifting strap, I’d have took it out my TD6.
Can get them on the bay of e though…
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #623190 10th Feb 2022 6:44pm
william Jones
Wales 2010 Range Rover Vogue TDV8 Santorini Black
I have just done this today, and it rectified my slow to access mode problem, great fix, cheers guys !
Post #662095 17th Apr 2023 11:01am
mjdronfield
Nice one. I appreciate it’s not the fix Land Rover would do, but no issues with mine…. However many years later….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #662108 17th Apr 2023 1:11pm
matthews
Had same issue when I got mine nearly 7 years ago , hole in filter sorted it (6/1//2 years ago) not missed a beat since and it get's lowered nearly every time it's parked (wife has little legs and easier for dogs to jump in boot ).
Post #662242 18th Apr 2023 8:38pm
