Home > Maintenance & Mods (L322) > How do i turn OFF automatic steering wheel Adjustment ?
robertisaksson
Sweden 2003 Range Rover Vogue Td6 Galway Green
I want to turn the automatic adjustmend OFF , the ( Easy acsess mode)
Can i do this without for ex the IID tool?
Post #622192 2nd Feb 2022 9:48am
is the info not in the owners manual? ... - .- -.
Post #622203 2nd Feb 2022 11:33am
robertisaksson
I cant seem to find info about turning it off!
Post #622204 2nd Feb 2022 11:35am
Re: How do i turn OFF automatic steering wheel Adjustment ?
No you need a diagnostic tool. Not necessarily a IID.
Post #622205 2nd Feb 2022 11:56am
robertisaksson
I looked at hawkeye, there is no defenitive anser for IF its up for The task, anyone sure?
Post #622206 2nd Feb 2022 12:04pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
I have the Hawkeye pro and can confirm it will not edit CCF files, for this I have to use my IID tool. 2011 TDV8 Vogue SE
Post #622209 2nd Feb 2022 12:13pm
according to this ,pulling fuse 20 in the passenger fusebox should disable it,
Post #622210 2nd Feb 2022 12:15pm
robertisaksson
I understand that, i do not want to disable The function, just the automation
Post #622213 2nd Feb 2022 12:21pm
Embarassed
Post #622215 2nd Feb 2022 12:29pm
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
Not sure if you have the TFT dash but if so it’s definitely in the menu to turn on and off, don’t know about the analogue dash though.
Post #622242 2nd Feb 2022 5:30pm
robertisaksson
Sry, 2003 so not tft 😢
Post #622246 2nd Feb 2022 5:35pm
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
I agree with earlier comment that you need an IID or similar.
I've removed fuse 20 as already mentioned, however that does mean the seat and steering wheel can't be moved. I made sure I set them up how I wanted them before I removed the fuse.
My reason for removing the fuse was because my steering was making a squeaking/creaking noise whenever it retracted, and I've just not got round to lubing the mechanism yet.
Post #622251 2nd Feb 2022 6:01pm
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
I checked this with my indy back when I still had my TD6.
Was having problems with the reach mechanism jamming.
He confirmed that it could be done if I (really) wanted it, but that it wasn't a user changeable setting (we didn't get into the Gap IID conversation).
On a related note it is critical that column reach is not permitted to rest on the stop (at maximum reach extension).
This will lead to a screeching noise and mechanism jamming.
If your driving position favours the outer reaches of travel, is a good idea to extend to maximum before retracting slightly and then saving to memory.
Also recommend checking the memory setting periodically to guard against possible "creep" occurrence.
I've found that this can see the column extending to the stop by way of easy entry.
Should this happen, you may not notice until the mechanism becomes noisy or jams.
And by then the damage may be permanent. 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #622258 2nd Feb 2022 7:20pm
