Home > Maintenance & Mods (L322) > L322 2006 td6 brake pad warning
Landmark
I all ,working on my mates l322 2006 td6 and replaced discs pads and sensors. Unfortunately on completion of work pad wear text and red warning keeps showing in an attempt to faul find I have disconnected both sensors and looped over turned on reset fuse and ecu using iid tool and then after about 30 seconds it comes back. I'm guessing the fault lies in loom anyone else had this or are there any hot spot faults ie known loom frett areas.
Post #621904 30th Jan 2022 8:26pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Was the warning on before the work you carried out ?
Post #621927 31st Jan 2022 8:26am
Landmark
Pad warning light
Yes it was
Post #621930 31st Jan 2022 9:16am
Landmark
Have used paperclip to link rear and front sensors removed fuse for dash and placed back in. Fault is cleared but then comes back after about 30 secs. I guess S the ecu runs its checks. Think there must be a loom issue what do you reckon.
Post #621931 31st Jan 2022 9:19am
bembo449
In the end i found the sensor wire had a break in it , new lead fixed the issue
Post #624165 19th Feb 2022 1:06pm
