![]() | Home > Maintenance & Mods (L322) > L322 2006 td6 brake pad warning |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
Was the warning on before the work you carried out ? |
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 ![]() ![]() ![]() |
Yes it was |
Have used paperclip to link rear and front sensors removed fuse for dash and placed back in. Fault is cleared but then comes back after about 30 secs. I guess S the ecu runs its checks. Think there must be a loom issue what do you reckon. |
In the end i found the sensor wire had a break in it , new lead fixed the issue |
