Home > Maintenance & Mods (L405) > Creaking drivers seat
James Brown RR
I have a 2013 SDV8 L405 which i have had for about 7 months - I have been slowly working my way through a list of fixes / improvements and I'm nearly there.
Last on the list is an annoying creak when sitting in the drivers seat which happens when i turn so my weight is shifting.
Has anyone had a similar problem or can suggest a good place to start to id the problem and fix? All ideas much appreciated.
Thanks in advance,
James
PS Loving the car and would never be without one SDV8 Vogue SE
SDV6 RR Sport
TDV6 Vogue SE
3.0D Velar HSE Dynamic
SDV8 Autobiography
Post #621317 25th Jan 2022 10:33am
ABAB
Can’t guarantee that it will fix your fault, but try the plastic trim which houses the seat controls - just to make sure it fits tightly. 2016 SDV8 AB
Post #621332 25th Jan 2022 11:39am
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
On my L322, the creak from my seat was from the belt buckle rubbing against the seat bolster.
Try holding the buckle away from the seat and shift your weight and see if it stops the creak. If it does, the some fabric tape will solve that!
It took me ages to find the cause of my creaks as it sounded like it was the center console, or inside the seat housing… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #621344 25th Jan 2022 1:04pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I had creaking front seats when I bought my 2013 SDV8.
Getting under the seat with a little bit of WD40 where the plastic and leather parts meet solved it and has not come back since. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #621352 25th Jan 2022 4:25pm
