Home > Off Topic > laptop fan
laptop fan
my laptop fan keeps on going all the time, it used to start and stop but now keeps on going basically from boot up..i've taken the back cover off and made sure theres no fluff blocking the vents...any ideas ?
Post #67413 7th Jun 2011 12:12pm
algt2
Scotland 2006 Range Rover Vogue 4.4 V8 Zermatt Silver
You may need to apply some fresh heatsink paste between the processor and the heatsink, or it may have leaked it's refrigerant from the chiller if fitted.
Post #67415 7th Jun 2011 12:26pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Sit in the fridge whilst using?...
Oh, sensible ideas!!! Wink Laughing
Post #67416 7th Jun 2011 12:28pm
thanks, do you think if i re-install the OS this might solve the problem
@rich.. Laughing
Post #67420 7th Jun 2011 12:39pm
supershuttle
@rich.. Laughing
Before doing anything complex, what I did was blast the airways through with a compressor, they were blocked with dust and fluff after that no problem. Geoff
Post #67427 7th Jun 2011 1:04pm
algt2
@rich.. Laughing
If the system is running slow and the HDD activity is pretty full on then a fresh install could help, its maybe worth a try, did a fresh Install on the wife’s laptop after cleaning inside with compressed air and applying new heatsink paste, made a huge difference to the time that the fan ran for but it only lasted a month or so Confused
Post #67459 7th Jun 2011 3:20pm
as time goes by i tend to load and un-load software to try out so hence my suggestion of a OS re-install, my registry must full of rubbish doing nothing...
when i have time i think i'll do this first then ask for more advice if it doesn't work....thanks ..
Post #67461 7th Jun 2011 3:32pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
If it goes full bore from the moment you turn on IE as the BIOS post's boot it will not be the OS and is unlikely to be anyway.
Dust
Cap on the motherboard going
CPU reporting the temp wrongly to the MB and also can be the CPU
Failing batts can also cause fan problems when the PSU for the laptop is on the limit to supply power to a failing cell in the Battery, try taking the Battery out and running just from the mains.
Try an updated BIOS first available from your laptop manufacturer. Far to many gone...
Post #67463 7th Jun 2011 3:39pm
you might have hit the nail on the head tbone, my battery doesnt hold charge and i brought a higher mAh off ebay which would not charge or read its voltage properly , sent it back and started using my dodgy one again..i'll try your suggestion of not having battery in and see if that solves it.. Thumbs Up
Post #67465 7th Jun 2011 3:47pm
tboner001
What model is the laptop ? Far to many gone...
Post #67467 7th Jun 2011 3:49pm
its an acer 5920..
Post #67469 7th Jun 2011 3:52pm
I think they all have a problem overheating....
I have one sitting in my office unused now as its simply gets to hot if you try to use anything that needs good graphics like a DVD etc...
Used to like ACER but not anymore Sad
Post #67492 7th Jun 2011 5:52pm
mine has served me very well for the last five years or so, but everything wears out i suppose...
Post #67499 7th Jun 2011 6:14pm
update, taken battery off and the fan still runs all the time.....need to do an OS re-install now..
Post #67661 8th Jun 2011 10:53am
comports
Or buy a MacBook Pro. I never hear the fan at all...ever....
I think the ally case acts as an enlarged heat sink so it never really gets hot.!
Thumbs Up Ash
2016 SDV8 AB
Post #67688 8th Jun 2011 1:55pm
