![]() | Home > Maintenance & Mods (L322) > EGR and intake system maintenance |
EGR delete - have yet to read about anybody doing it successfully. Removal of the intake plenum on top of the engine to clean out the oil and soot crud is a common but very messy task ( do a search) cleaning of the throttle plate is probably wise but cleaning the MAP sensor is essential and easy - remove and blast out the crud with brake cleaner. These block up very quickly and a check and clean every 5k miles is worthwhile. Also check for any leaks on the intake or a split in the plastic seams which a coating of oil and soot will giveaway. 2012 TDV8 Vogue (L322) |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
The general consensus on this forum is to leave the EGR in place. There is conflicting arguments on its purpose with the DPF filter, with a few arguments that suggest removing it from use doesn’t affect the DFP… as as mentioned by JayGee we don’t have posts claiming “its all fine” from anyone.
This is mine on a 120k car…
Jimmies Member Since: 19 Jan 2022 Location: N.Yorks Posts: 24 ![]() ![]() ![]() |
Awesome, thanks for the head start
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1278 ![]() ![]() ![]() |
My favourite picture of what I got out of mine. Get yourself some disposable gloves mate.
I keep dreaming of a clean intake system but have nightmares about the kind of mess I'd create achieving it. Also the speed at which it would build up again after logging how often the EGR valve is open (most of the time) and cycling this stuff through the intake. 2012 TDV8 Vogue (L322) |
Looks like the wife's cooking |
That’s a lot of crud. Did you have an issue that caused that, or is it normal? At what mileage did you tackle that job? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Normal for these engines. EGR valve open under most driving conditions so exhaust continually cycling through the intake. 2012 TDV8 Vogue (L322) |
It's quite common on diesel engines. My butterfly valve was sticking a bit causing jerky off throttle acceleration from stand still. |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 331 ![]() ![]() |
We've researched EGR and DPF deletes extensively on the 4.4 TDV8 and taken advice from very experienced modifying shops as well as LR chief mechanics.
Thanks all
If it's running fine I would just clean the MAP sensor only mate. The inlet hose has a seal inside and you risk it leaking if you disturb it. You can't buy the seal on it's own meaning buying a new hose. |
