Home > Technical (L322) > 4.4 tdi inlet manifold hoses
misfire84
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
inlet manifold hoses I am thinking of changing mine as they are looking a bit manky , the inlet manifolds are ok , do I go for standard dealer parts at £££ or can I use silicon hose with proper hose clips if so what size do I get ? black or i am tempted to order red . 2012 Black 4.4 TDV8
1968 Mgb Gt
Post #620693 20th Jan 2022 2:35pm
mjdronfield
I think there were issues with the ones fitted at the factory, and the current new parts from Land Rover are much better.
That said, silicone I believe is the way to go if you can.
I’d go red or blue if it were me, you don’t see them under the cover anyway, and might stop a garage binning them etc if they see they are not the iffy factory ones…
No idea on sizes though. Never done it.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #620703 20th Jan 2022 4:20pm
JayGee
A 2012 car 'should' have the upgraded ones. I'd just buy some silicone hose and cut off 4 sections if you want to replace them and don't want to pay dealer prices. 2012 TDV8 Vogue (L322)
Post #620706 20th Jan 2022 4:29pm
DrRob
Use the Search function and put in silicone. Should throw up some useful stuff
https://www.fullfatrr.com/forum/search.php Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #620710 20th Jan 2022 4:56pm
DrRob
For example
https://www.fullfatrr.com/forum/topic58355...t=silicone Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #620711 20th Jan 2022 4:57pm
JMC
I paid about £50 for a one-meter length of 70mm ID silicon tube from a uk manufacturer (not some random Chinese stuff off ebay). The plan was to replace the OEM items, as I expected they'd be in a poor state after nine years. However, when I removed the plenum on my 2012, the existing rubber looked new! The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #620726 20th Jan 2022 7:45pm
misfire84
DrRob wrote:
For example
Thank you I tried inlet hose but did not try silicon ... all the info is there if you ask the right question ! thank you again ... 2012 Black 4.4 TDV8
1968 Mgb Gt
Post #620774 21st Jan 2022 1:21pm
