Home > Technical (L322) > 4.4 tdi inlet manifold hoses |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
I think there were issues with the ones fitted at the factory, and the current new parts from Land Rover are much better.
20th Jan 2022 4:20pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3206 |
A 2012 car 'should' have the upgraded ones. I'd just buy some silicone hose and cut off 4 sections if you want to replace them and don't want to pay dealer prices. 2012 TDV8 Vogue (L322) |
20th Jan 2022 4:29pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Use the Search function and put in silicone. Should throw up some useful stuff
20th Jan 2022 4:56pm |
For example
20th Jan 2022 4:57pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
I paid about £50 for a one-meter length of 70mm ID silicon tube from a uk manufacturer (not some random Chinese stuff off ebay). The plan was to replace the OEM items, as I expected they'd be in a poor state after nine years. However, when I removed the plenum on my 2012, the existing rubber looked new! The older I get, the more I realise that people confuse wrinkles for wisdom |
20th Jan 2022 7:45pm |
misfire84 Member Since: 25 Nov 2020 Location: brecon becons Posts: 37 |
Thank you I tried inlet hose but did not try silicon ... all the info is there if you ask the right question ! thank you again ... 2012 Black 4.4 TDV8 1968 Mgb Gt |
21st Jan 2022 1:21pm |
