Home > Maintenance & Mods (L322) > TD6 Alternator Replacement and Viscous Fan Removal.
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Well the time finally arrived after 20 years the alternator was failing and required replacing . Purchased a new one of line removed the old one and fitted the new one without issue. I had read up about removing the viscous fan and shroud so Purchased the relevant land rover tools (lrt-12-214 and 32mm spanner) . Discovered that all was reqwas the 42mm thin spanner and a large adjustable ! Wasted £103 on the special spanner! If anyone else with a TD6 wants to remove their viscous fan then don't make the mistake I did in purchasing the special spanner .I have now left the fan and shroud off and cannot believe the difference in lack of noise ! Test run car and all working perfectly so will not be refitting the fan any day soon 😉
Post #620587 19th Jan 2022 4:22pm
Thumbs Up Thumbs Up Thumbs Up .
Post #620637 20th Jan 2022 12:24am
