Home > Maintenance & Mods (L322) > gearbox oil
Harlin
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
gearbox oil
hi all
can anyone tell me what sealing washers i need for the drain cap and filler cap for a 4.4 03 petrol gearbox oil change
also what is the best oil to use to top up gearbox
part number 5hp24
model no. 10580000322
this is gearbox part numbers
Post #619575 11th Jan 2022 3:12pm
dhallworth
If yours is the 5 speed ZF gearbox, I believe the correct gear oil is LT71141.
There are a few different variants out there. In my 6 speed I've used a Smith & Allen alternative to the genuine ZF oil and it's been great so far so might be worth giving them a call to see if they've got one for the LT71141.
Give Duckworths LR a shout (They're a forum sponsor) and will be able to sort you out with the washers.
Post #619580 11th Jan 2022 3:21pm
Harlin
thank you , ill give them a call
Post #619624 11th Jan 2022 8:23pm
RRPhil
The drain & filler plugs have recessed seals rather than washers and these aren’t available separately. You could either re-use your old ones or buy new plugs if you prefer (UYP000070 & LR007610)
Opie Oils sell Mobil ATF LT 71141 for £12.15 per litre (if you use the coupon code FULLCHAT) and delivery is free on orders >£75.
Phil
Post #619660 12th Jan 2022 12:01am
Harlin
thanks very much for that mate,
just another quick one do you know how much oil the gearbox will need
cheers
Post #620174 16th Jan 2022 12:57pm
