![]() | Home > Technical (L322) > Heater fan not working |
Just to sure now l personally would check every other fuse. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7878 ![]() ![]() ![]() |
Any further help?
Brerfox Member Since: 22 Dec 2021 Location: Wales Posts: 16 ![]() ![]() ![]() |
hi I've just replaced mine, wasn't toobad a bit fiddly but no cutting involved. I checked every fuse and then replaced the hedge hog which we do have. and then replaced the fan. there is a video on how to take the dash out, difference is you have to take both side vents out and also both glove boxes have to come out remember not to close them when you disconnect the power my tip would be to buy a small screwdriver set the one with a bendy wand type thing. oh and the fan new of eBay £40 |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 351 ![]() ![]() ![]() |
Hi Brerfox that sounds promising do you have any more info on things I need to do, I’m good with spanner’s but it’s the takingbthe dash out I struggle with so all the info / tips you can give would be a great help 2012 Range Rover Westminster 4.4 TDV8
