![]() | Home > Maintenance & Mods (L322) > Dead Battery |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7874 ![]() ![]() ![]() |
Yes, they don’t like low battery voltage. I recon they struggle to power the clock when left to their own devices for too long 🤣.
Chrali Member Since: 13 Apr 2017 Location: Norwich Posts: 122 ![]() ![]() ![]() |
I thought the 4.4 tdv8s all had AGM. Was your original battery not? Encourage alternative fuels, use all the petrol!
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
LR changed the battery to an AGM on the >11MY after the early build run. Also retrofitted them to those already dispatched.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
It was the original battery as far as i can tell it was branded LR.
So just an update on this issue!!
ok So fitted the genuine LR brake Pedal switch and ............still no joy!! so yesterday i thought i am just going to drive it see if the switch needs to settle into a position.
