![]() | Home > Technical (L322) > Happy New GEAR!! Is it a healthy year for my gearbox? |
madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137 ![]() ![]() ![]() |
I bought them on eba y and from suppliers on the web, sonnax only sells them to its sellers |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 167 ![]() ![]() ![]() |
Did you also do the valves in the pump cover? Because that is a transmisson out job...
the first thing you notice is the consumption, the second the speed fluctuates, the engine brake is completely missing, after about 1000 km that I felt the rubbing, the gearbox went crazy, it was climbing and revving and dropping by itself at constant speed.
https://www.sonnax.com/tech_resources/132-...rse-or-tcc
I also feel that consumption seems to decline. Revving is most of the time very stable. Only at 70 kmh it sometimes goes up by 50-100 rpm. That yours did go bang in 1000 kms is bad luck. I will keep an eye on how mine behaves. The revving is hardly noticeable. In the mean time I'm going to dive into the Sonnax info you posted. Thank you! |
In the meantime I got a very friendly reply from a Sonnax Product Support Specialist |
this is interesting |
Now I wanted to see how my box and TCC behave. So I hooked up the IID and recorded a run from stand still (parking place) up the motorway.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1001 ![]() ![]() |
The vehicle speeds that you’re mentioning are for the ZF 5HP24 transmission, which doesn’t have a torsional vibration damper in the LUC. The GM 5L40-E torque converter does, so its calibration may be quite different.
Thanks for your reply Phil! |
Hello Phil, recorded some more files yesterday, but as I came home yesterday my laptop was toasted. |
Hello Phil,
Joep,
